Rubenbmx183
- Oct 20, 2021
- Reaction score
- 0
- Location
- Miami
- Make / Model
- Ford ranger 2.5
- Manual
Hey guys so over a month ago I turned on my 2000 Ford ranger 2.5 and it was just misfiring so I changed all 8 spark plugs and all 8 spark plug wires and nothing, I changed the coil pack closest to the back since there wasn’t spark on cylinder 4 and nothing. So I check my catalytic converter after a night drive and it was red as a tomato so I cut it off and welded and it did nothing…. My mass airflow sensor looks new but just in case I cleaned it and still have the same misfire…… I put a scanner through and get codes, p1506 (IDLE AIR CONTROL OVERSPEED ERROR) I also get p0304 (CYLINDER 4 MISFIRE DETECTED) and the last code I get is p0171 (SYSTEM TO LEAN BANK 1) I TURNED OFF THE CAR ONE NIGHT COLD AND TURNED IT BACK ON RIGHT AWAY AND THE MISFIRE WAS COMPLETELY GONE UNTIL 5 MINUTES LATER AND THAT LUCKY MOMENT NEVER CAME BACK WTFFFFF. Also sometimes when in neutral when I rev the engine the misfire is gone but once you put it into gear and start rolling the misfire is back and most of the time now even just revving it you feel the misfire… What do you guys think this misfire is?
