2000 F150 V6, what T-case?
pjtoledo
2,965
Toledo Ohio
Fords
3.0 2.3
found a manual T-case in a 2000 F150 V6 auto tranny. any chance it's a BW1354? or will bolt to a Ranger M5OD?
will the shifter fit a BW1354? can it be easily adapted?
1FTZF1828YNA50824 if that helps.
couldn't get under it to look, probably too big.
17,827
SW Iowa
Should be BW4406 and completely incompatible with a RBV transmission.
17,827
SW Iowa
Not to mention the incompatibility with the frame.
Actually rather popular for V8 swaps in 98+ trucks. IIRC fastpakr has one in his truck.
I thought there was a width issue. Too many transfer cases.
pjtoledo
2,965
Toledo Ohio
Fords
3.0 2.3
are 4406's worth grabbing for future use/resale?
no idea what they want for it yet.
Craig0320
225
Mississppi
Break it right the first time. Fix it better the next time.
I have a manual shift 4406 in my 98 5.0 Ranger.
Ranger850
Doesn't get Sarcasm . . .
4,691
Tallahassee Florida
Stock 2"
Stock
fastpakr
2,832
Roanoke, VA
If it's a manual shift 4406 and includes the linkage, definitely see what they want for it.
Adsm - it's a big case, but it definitely fits. One of the top bolts is a pain to get to on a Ranger install, but otherwise it's all good. With a one inch body lift it fits like it was made to be there.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
fit good. work great. way better then a 208.
17,827
SW Iowa
pjtoledo
2,965
Toledo Ohio
Fords
3.0 2.3
it was indeed a 4406,,,,44-06-000-021 to be exact. XL34-7A195-AC
that t-case, the entire shifter assembly/boot/stick is now at my place. got the front drive shaft and a baggie of bolts too.
