2000 5.0 Explorer Swap Into 98 Ranger 4.0
Craig0320
225
Mississppi
Break it right the first time. Fix it better the next time.
I checked my mileage. Did some running around town and back roads to the house combo. I am getting close to 19 mpg. I was down to 17 no matter what. What a difference. I am going to have to wait for a little while before I can change the sender because I just got the transmission back for my 3/4 ton so I have to put it back in.
DonovanJM
8
Washougal, Wa
Ranger XL
Do you guys know if when going from manual to automatic if the steering shaft with the shifter and gage cluster from the Explorer are direct swaps? The less I have to hunt down the better.
Thank you!
Craig0320
225
Mississppi
Thank you!
The steering column is the exact same as the ranger. You will need to just swap the whole thing in from the explorer. It will be much easier. The factory bolts in a plate on the floor to cover the hole for the shifter in an automatic ranger. Look for one of those at the junkyard. The gauge cluster is the same but you will have to change a wire around to make your tach read right depending on what engine you have.
fastpakr
2,832
Roanoke, VA
Wouldn't the Explorer have the floor plate he'd need?
DonovanJM
8
Washougal, Wa
Ranger XL
Either way is fine. I'm sure I will be making a trip to junkyard at least once. :ROFLMAO: I'll definitely check the explorer first though. The more I can get from the explorer the better. It's nice to know there is an OEM cover. It will look a lot better then what I would make.
Craig0320
225
Mississppi
DonovanJM
8
Washougal, Wa
Ranger XL
So another question. Everywhere say's the AWD is the easiest to swap. Is that because it's a direct bolt in? I plan on either getting the adapter and using my 1354 or swapping to something else. Haven't decided yet. With that in mind does it matter if I get an AWD or 4x4 Explorer? The 4x4's are much easier to find.
Thanks again.
fastpakr
2,832
Roanoke, VA
Forget the adapter. You have two reasonable options. The Explorer's AWD case is simple because there's nothing to it - the parts come with the truck, including the front driveshaft you'd need. Just get a rear driveshaft and you're ready to go. That said, a lot of us prefer having a true 4wd case with low range. For that, look at this thread:
https://www.explorerforum.com/forums/index.php?threads/convert-v8-awd-to-bw-4406-manual-shift-a-how-to-thread.166726/
Source a transfer case with shifter from an F150. You'll have to cut a hole in your floorboard for the shifter and do a little work for the shift lights, but that's it other than getting driveshafts to fit.
DonovanJM
8
Washougal, Wa
Ranger XL
So if I went this method would I still need to find an AWD Explorer or will a 4x4 be fine?
fastpakr
2,832
Roanoke, VA
The Explorer donor won't be 4wd. All the 5.0 Explorers were either 2wd or AWD. I actually used a 2wd donor, but separately sourced a transmission from an AWD 5.0 Explorer.
DonovanJM
8
Washougal, Wa
Ranger XL
ah, that makes sense! Thank you!
G8orFord
803
FL
4.0 SOHC S/C
Just the right size to touch the ground.
Why skip the adapter? If there is an adapter made that allows the use of the existing Ranger t-case, why not use it instead of cobbling together parts from other vehicles to make a manual shifter work? Is the Ranger t-case not strong enough? Are there other issues? I'm just trying to learn, because I've been seriously considering the V8 swap on my '01.
fastpakr
2,832
Roanoke, VA
Because the F150 case is immensely stronger, and because it gives you an opportunity to go with a manual case. There isn't much cobbling to it. Alternatively, you're sourcing an expensive adapter to use a weaker case.
don4331
1,346
Calgary, AB
5.3
Because we are cheap, lazy or both.
The BW1354 shaft installs from the front of the 4R70W. So you will need to pull everything out of transmission - pump, gears, clutches, etc to remove the existing output shaft and replace with the one for Ranger transfer case. It's OK, if you were planning on rebuilding the transmission anyways, but it is a lot of work if you have a good transmission. And a lot of people are intimidated/don't have tools to rebuild an automatic.
Note: Swapping the transmission to transfer case housing is child's play, so I am discounting the requirement to do that.
The Advance Adapters sells the shaft for ~$600 US with availability occasionally being sketchy. $1k Cdn after purchase, shipping, duty made me look into other solutions.
And ya, the 31 spline input shaft/34 (BW1356) or 39 (BW4406) tooth gears of F-150 case are substantially stronger than the 25 splines/24 tooth gears of the Ranger case. And the BW4406 can be found in electric shift models that basically bolt/wire in (look for Expeditions of same vintage as your Ranger), if you don't want to cut the floor up. The BW4406 is also only 14.5mm (~9/16") wider center to center than BW1350/4, so fits between frame rails a lot nicer than BW1356.
