Bird66
- Feb 4, 2019
- 0
- Salina, Kansas
- Ford
Hi, I'm new to the forum.
So I bought a 2000 Ford Ranger 3.0l automatic XLT 4x4 Flex Fuel 8th digit: V with 156k miles with a seized engine (cam synchronizer failed). It has been sitting for about a year and pack rats had chewed up the wiring harness a bit.
I found a 3.0l engine out of a 99 2wd that had already been pulled. The lady said she thought it was a non flex fuel. She also told me that it had 70k miles. After I brought it home I noticed that it had a heat tab in the block, so I assume it was a junkyard motor that was put into her truck and then pulled again before I bought it.
I fixed the wiring and put the good engine in my truck using the flex plate block, heads, lower intake and the fuel rail. Everything else came off the original engine(exhaust manifolds, upper intake, coil pack, and the rest of the dressings). Also installed a new cam synchro, water pump, plugs(wires seemed new so we left those for the time being) and cleaned the MAF sensor.
The engine started up but runs rough and has no power. Computer shows 44% engine load at idle. Ran it for more than 30 min and drove it about a mile and no check engine codes yet.
Has a squeaking noise that comes and goes. It is similar to a belt squeak and an exhaust leak at the same time but is not the belt and don't think it has an exhaust leak either. When listening at the tail pipe sounds like it may have some exhaust suck. We also smell fuel while running.
We tried a few different firing orders but no change and added some sea foam to the tank. It does have fuel pressure. Did a quick check for vacuum leaks and didn't find any.
This weekend we are planning to put on the new plug wires, check compression in all the cylinders and try using the other coil pack. We could also try swapping the fuel rail along with the fuel injectors. I might also swap out the cam position sensor and may be the shaft also to try to fix that mystery squeak.
My questions to the forum are:
Does anyone have any ideas or experience with what this problem is or might be?
Are there any things I should check or try to swap other than what I plan to try this weekend?
