2 Questions, been a lil minute
88workcar
49
Pierre Part La.
Ranger XL
Check the picture, this is the only position that the compressor does not kick on and off. Any other spot and it cycles. Is this correct? If not, how do I fix it?
Grumpaw
1,504
Virginia
Ford Ranger XL
Stock
Stock
Stock 225/70/15
I don't count birthday's anymore...just happy to be looking down at the ground instead of looking up
The ac compressor should only kick on when switch is on AC or Max AC .
You have it at the upper vent position, which will allow outside air in thru the upper vents.....no ac, just outside air, whatever it' temp is.
ericbphoto
Overlander in development
16,594
Wellford, SC
3.0L
6"
Not quite right. The A/C is used to remove moisture when defrosting/defogger the windows.
I believe it is natural for the compressor to cycle. It does that based on t GJ e pressures caused by the heat load on the system. But if it cycles too frequently, that is a sign of a problem.
Grumpaw
1,504
Virginia
Ford Ranger XL
Stock
Stock
Stock 225/70/15
My bad bout the defrost cycle. But it shouldn't come on when in the vent position, should it ? At least my 2009 dosen't. Never noticed if it came on during defrost cycle...don't use it that often.
rusty ol ranger
2.9 Mafia-Don
7,492
Michigan
177 CID
Defrost, AC, and max AC are the only times the compressor will cycle
19Walt93
4,465
Canaan,NH
351
3"
235/55R16
It will also cycle in the mix position. Off, Floor, and Vent are the only ones where it doesn't engage. Before they were set up that way a lot of compressors would seize from sitting during the cooler/colder months- in NH from late September to late May for example.
88workcar
49
Pierre Part La.
Ranger XL
It is my belief that AC, Max AC, and defrost should be the only spots it cycles the compressor. So ……. any suggestions on why mine isn't working correctly?
pjtoledo
2,965
Toledo Ohio
Fords
3.0 2.3
ACs been designed to run in both windshield positions since at least 1976.
ericbphoto
16,594
Wellford, SC
3.0L
6"
If thats what you want, you will have to rewire the controls to do that.
Does your A/C system cool properly? Or is there a problem with it cooling?
ericbphoto
16,594
Wellford, SC
3.0L
6"
I would recommend getting the EVTM for your truck.
Here is a picture of the switch schematic for my 97 F150. Yours should be very similar. There have been slight changes over the years. My 93 Ranger runs A/C any time defrost is selected or A/C is turned on (any vent selection). But it has the older style slider control with pushbutton for A/C.
This shows power to A/C compressor in the following positions (97 F150)
Max A/C, A/C, panel/floor, defrost/floor, defrost
pjtoledo
2,965
Toledo Ohio
Fords
3.0 2.3
well hells bells, I never knew about "slugging"
2005 manual.
52465
the PCM has the ultimate control of the AC clutch, it activates the AC relay.
8,370
2001 AC control wiring below
Only positions that have AC OFF are Vent and OFF, all other settings send the 12volt "demand" signal to Computer(PCM), on the Violet(VIO) wire from pin 2 on control knob
black_demon69
142
AZ
4.0l
88workcar
49
Pierre Part La.
Ranger XL
My AC works awesome, I see that with you fellas awesome explanation and details that my system is working the way FORD designed it. Well dam.... I don't have to like it tho LOL. Thanks y'all, we can always count on y'all. Case Closed :)
sgtsandman
Aircraft Fuel Tank Diver
U.S. Military - Active
Ham Radio Operator
12,646
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
They “improved it” around 2009 or so. The A/C system engaged in MAX, A/C, dash and floor, windshield and floor, and windshield only. The only two modes the A/C doesn’t come on is dash only just after the off setting and floor only.
The Japanese got it right when they installed a separate button for the A/C system in their vehicles. The Ranger finally caught up with that with the 2019 model year.
