2 post lift recommendations
2drxploder
434
usa
ranger
347
lower
235 on 15s
building a shop, want a lift. sidewall height will be 12' clear. my vehicles are: 03 ext cab shortbed 6.0 diesel f250, 99 ranger, 82 bronco on 40s. gf has small suvs. on to the lift will be a 2 post for sure. but that is where i get lost, symmetrical, asymmetrical, bar on top, drive over, 9 or 10k, enough? what brands? budget wise hopefully 3k?
lil_Blue_Ford
6,125
Butler, PA, USSA
4.9L
Unfortunately I don’t know a ton about them other than Bend Pak is a good name and the asymmetrical usually gives you a little more room to open doors. I’ll definitely be following this thread because I’m looking to build myself a garage (hopefully this year but may be next) and put a lift in it. Tired of working in dirt and gravel on my junk.
sgtsandman
Aircraft Fuel Tank Diver
12,634
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
Cardboard from an appliance makes work in the gravel much nicer.
lil_Blue_Ford
6,125
Butler, PA, USSA
4.9L
sgtsandman
12,634
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
I have some 2” thick foam rubber pads that I use
Well, EXCUSE ME Mr. Fancy Pants. You and your fancy rubber pads! To good to use cardboard like the REST of us! 🤪
17,805
SW Iowa
I use my 25 year old foam sleeping mat from when I was in boy scouts...
lil_Blue_Ford
6,125
Butler, PA, USSA
4.9L
I also have a couple of the foam pit mats from Summit Racing :thefinger::icon_rofl:
sgtsandman
12,634
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
17,805
SW Iowa
How heavy is your '250?
Dad's gas 2wd '250 is about the max for my brother's main lift at work, it has a service body on it though.
Craig0320
225
Mississppi
Break it right the first time. Fix it better the next time.
I have an Eagle 11k asymmetrical two post lift with the top bar. I love that it has a bar on the motor side for single point unlock for the dogs. Only trouble I've had is lifting some vans all the way. I can still drop the trans and gas tank relatively comfortably still. The difference between asymmetrical and symmetrical is:
asymmetrical- allows cars to set off center (front or back slightly) of lift post to be able to open doors easier
symmetrical- doors are little harder to open and get out of because the vehicle sits directly in the center of the lift post.
60567
2drxploder
434
usa
ranger
347
lower
235 on 15s
@Craig0320 how high is this lift from floor?
@85_Ranger4x4 interweb says about 7k but that seems light too me.
lil_Blue_Ford
6,125
Butler, PA, USSA
4.9L
Craig0320
225
Mississppi
