- Sep 22, 2007
- 7,491
- Michigan
- Ford
- Engine Type
- 2.9 V6
- Engine Size
- 177 CID
- 2WD / 4WD
- 2WD
- My credo
- A legend to the old man, a hero to the child...
Mine will randomly max the gauges out sometimes. You can tell cause they all go up in unison.Has anyone had trouble with their instrument panel voltage regulator?? Mine seems to have shit the bed as my gas gauge reads full no matter (has new sending unit). With alternator wired up separately, isolating it from the wiring going to cluster, it runs great . However, after test drive, under load it stumbles for a second like it dies outright for a split second (had similar issue before but it was more severe before and more often).
This voltage regulator is hooked in to my ignition and they are know to go bad. It’s also hooked to my gas gauge. And the alternator. So if it’s intermittently shorting, it could be what’s the matter with it all.
Update: put junk yard volt reg in cluster and it was mildly better but when we bench tested that one, it too was bouncing from zero to 7 volts. On our way to buy a steady volt step down 12v to 6v from electronics place and hoping that’ll sort it and bring gas gauge back and allow for alternator to be hooked up business as usual.
Anyone had issues with these f***ing things before let me know
Never had any other ill effects though
