DankTank
- May 26, 2017
- Reaction score
- 0
- Location
- Oklahoma
- Make / Model
- Ford
- Engine Size
- 2.9L
- Manual
- My credo
- If it ain't broke, fix it 'til it is...
I have a '86 Ranger running a '87 V6 and want to check the EGR system. I've heard most cars can detect if the EGR is inactive/not connected and can correct timing, fuel, etc... accordingly. Although I'm not sure if my '86 computer can do that or not. I'd like to be able to disconnect the EGR to see if it works better, but I'd rather not have it misfire and then not get my answer anyway.
If it is the EGR, how safe is it to delete? Apparently deleting the EGR can cause an engine to run hot and misfire. If that's true, how do the '88+ engines run without it, and with the same V6 as the older trucks?
For reference, the issue I'm having is an idle issue when the engine transitions from 'warming up' to 'warm.'
