2.9L cold start issues
Junkyardexpress
ASE Certified Tech
Ellsworth,Maine
2.9L
P235/R15
I have a 91 ranger with a 2.9 out of a 90 brII.When i start it first thing in the morning it fires right up then immediately stalls:annoyed:.It has a new fuel pump,filter,relay,pressure regulator.
kimcrwbr1
46
maplevalley WA
2.8l
Clean the throttle body and idle air control the best way is to pull it off spray/soak it with carb cleaner and blast it good with the hose. Make sure you get a new throttle body gasket to put it back together first. It will probably just help to clean around the butterfly and the IAC might be sticking but I would start there.
Junkyardexpress
ASE Certified Tech
Ellsworth,Maine
2.9L
P235/R15
does anybody have any other suggestion?
i cleaned the iac and no difference i also didn't mention this a non EGR/MAF engine and i have done the K&N filter mod
Does it still stall if you hold the throttle partway open?
Junkyardexpress
ASE Certified Tech
Ellsworth,Maine
2.9L
P235/R15
i will try that tomorrow and if it's about 40 or above it will just stumble and then smoothe out to a steady idle and yes i've replaced the temp sensor
fyre82
Firefighter
6
Lake Almanor, Ca.
2.9/4.0
9" on the 2000, 6" on the '88
265/75/16, 31x10.50x15
The memories of a man in his old age are the deeds of a man in his prime
Does it restart without problems?
Mine does that when it is cold, it lives outside.
Pull codes to see if it has a registrable issue.
Junkyardexpress
ASE Certified Tech
Ellsworth,Maine
2.9L
P235/R15
start stalls then starts and runs fine and rest of the day it's no problem
Junkyardexpress
ASE Certified Tech
Ellsworth,Maine
2.9L
P235/R15
what does the air temp sensor control
