LtDuke
- Jul 6, 2020
- 0
- Ford VA
- Ford Bronco II
Hey guys, I got a 1989 2.9l that I've been thru hell with. It surges at idle and drinks fuel while underperforming where it should.
New parts: fuel tank, fuel pump, injectors, spark plugs, wires, coil, cap & button, timing chain, O2 sensor, idle air sensor, map sensor, water temp sensors, O2 inlet temp sensor, upper intake manifold gaskets, timing chain, new battery to block ground, computer swapped from a 89 ranger with same set up.
No vaccum leaks found by me, the shop, or shade tree mechanic. I'm stumped.
No vaccum leaks found by me or the shop or 2 shade tree mechanics
