kodogtwh
- Mar 1, 2021
- 57
- North Carolina
- Ford Ranger
2.9s are slow. In a truck application. If I owned an mx-5, it would get a 2.9. Very big British sports car vibes. But I don't, so here's my little solution to the 2.9 slowness.
Ebay turbo, generic t3/t4 sizing.
Ebay intercooler, way too big, but it fits my needs (and fits between the frame rails quite nicely)
Hot side crosses under the truck from the factory y-pipe, under the frame rail and will tuck along what's left of my fender liner to the turbo. outlet will follow a similar path. Surprisingly, the piping will clear the suspension and wheel at full compression, from lock to lock, with reasonably large 285's.
Fuel system:
Bonus pic of my slow car being pulled by my other slow car.
Fuel system:
- Ford taurus SHO 3.2 injectors, should support roughly 240bhp at the crank. Well within what I expect.
- Walboro 255lph pump from a local swap meet.
- upstream pump bypass/delete, stock replacement filter
- Stock coil, cap, rotor, wires. NGK heat range 7 Iridium plugs gapped at .020
- Vestigial TFI, used only for the PIP signal, direct coil control from an MX-6/Probe turbo coil igniter
- Microsquirt (module only) wired to an EEC-IV Connector in the original ford PCM box. a DIYPNP if you will.
- 160 thermostat
- ebay TIAL knockoff wastegate with a 10lb spring
- AutoMeter analog wideband
