2.9 to a gm 4.3
GDAWGMX396
Is it possible to swap out a 2.9 to a 4.3 gm v6? And if so is there an adapter plate for it? I have this motor in my garage.
dangerranger83
5.0 HO under the hood!!!
54
Lafayette, IN
The 4.3 would rip your 2.9 tranny up. Get a tranny for the 4.3 that hooks to it, shares the same bolt pattern as the 350 (and maybe others).
As far as bolt in, no, but it can be done, I have seen 350's put under the hoods of rangers. The 4.3 is a 350 minus 2 cyclinders.
--weezl--
June 2011 OTOTM Winner
Law Enforcement
182
hell
i hope you change your mind... i honestly believe there is one place a chevy motor belongs... that's in a chevy...
dangerranger83
54
Lafayette, IN
I have no problem with chevy engines....I just have problems with dodge engines and trannies until you get into the diesels.
Its your truck do what you want to it.
Hahnsb2
36
Battle Ground WA
Ford-Dodge
4.0-5.2 Turbo
The 4.3 is a good engine but the 4.0 does the same thing and is easily swapped in.
Funnyman141
9
Fort Madison, IA
2.3, 4.0
well, he already has the motor, basically you would have to look up sbc swaps since they are basically the same, you'll have more room up front though :D
Spacesuitrudi
4
South Carolina
Ford Ranger 4x4
302
Solid Axle Swap 4x4
I know it's been a while, but did you ever complete this? If so any advice? I was just gifted a wrecked blazer that was running just fine before it wrecked and was wondering how hard it would be to swap into my bronco ii
Ranger850
Doesn't get Sarcasm . . .
4,685
Tallahassee Florida
Stock 2"
Stock
It's been over 10 years, with no response. Probably didn't happen, or he's over on a Chevy forum.
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
It's similar to a 350 as mentioned.
2wd or 4wd application? I would assume 4x4....but some b2 are 2wd.
Great engine. Tows better then a 4.0.
Exhaust manifold can be tricky, I originally in 92-93 was going to replace my 2.9 a-fail-od combo with a 4.3 5 speed setup.... As trading and parts swapping ensued I ended up with a 302 setup ... After trading a lt1 off ....
That be will be a beast with the 4.3.
