2.9 pilot bearing
87RangerXLTct
Just looking for conformation that the pilot bearing does in fact get installed in the flywheel.
I just pulled my fm145 that failed due to an inputshaft bearing and there was a pilot bearing in crank shaft and none in the flywheel, flywheel just had that counter bore.
Which is now too large a bore to except a bearing. So I think I need a new flywheel.
Thanks
RobbieD
1,035
Georgia
On a 1990 2.9L 2WD Ranger with the Mitsu FM132 it was in the flywheel. Can't confirm first-hand, though, for any other years with the 2.9L.
87RangerXLTct
Mines an 87 with fm145 4x4. I noticed on pilot bearing tech article on this website it says 2.8,2.9, and 4.0 it's installed in flywheel just makin sure
Paulos
204
North Carolina
1987 STX
It's definitely in the flywheel. If I recall correctly, a 9/16" socket works great to press or tap it in/out. Check the pics of it here
