- Jan 11, 2012
- 13
- Washington State
- Ford
- Engine Size
- 3.0
Trying to isolate reason for miss / shudder with high idle in 86 2.9 engine. Fuel pressure solid 30. Base timing set to 10 deg btdc. Cap and rotor new and clean. Plugs new and clean. Wires new. Spark present at all 6 cylinders tested with spark tester light. Vacuum steady at 25 or so. IAC and TPS both new, wires and connections good. Checked all vacuum lines I can find and seem ok.
When setting timing, with the spout connector out, the mark is rock solid at the pointer, as soon as I plug in the spout it advances to around 20, fluctuating and the idle jumps up.
I tested for a vacuum leak with spray all around the intake manifold and got no change in the idle.
So, having walked away from it in frustration, I thought it must be time to ask for help from the best and brightest here. Any input is greatly appreciated!
