2.9 barely runs sounds like it’s only running on 2 cylinders need help asap
That_4.0_ranger
152
Appleton,W.A.
4.0, 2.9
stock
31x10.50-15
I was leaving my neighbors house and the truck dies it is barely running sounds like it is only running on 2 cylinders I have no idea what is wrong if anyone can tell me some sensors to test or even a temporary fix to get it home I would really appreciate it thanks
Bronco ii Man
43
Southport NC
Ford Bronco ii
2.8 V6
2.8 v6
31x10.50-15
Check for spark and make sure you getting fuel to the injector’s. Start there and see what you have.
That_4.0_ranger
152
Appleton,W.A.
4.0, 2.9
stock
31x10.50-15
I checked all that so I ran my code reader and found I have a bad tps a map sensor
Bronco ii Man
43
Southport NC
Ford Bronco ii
2.8 V6
2.8 v6
31x10.50-15
Glad you figured it out!
