UPDATE: I got her running good. Now, Im having starter issues. I cant tell what the issue is and what's causing it.
The starter keeps getting stuck in the flywheel teeth. Is that starter or flywheel related? Because it happened twice. I'm fixing to just buy a new starter from rockauto if its the starter. It happened 2 times in a row. The Bendix keeps getting jammed inside itself. Like when I remove the bronze/copper cap it's stiff and takes a few smacks with my rubber mallet to get it to go back in. Then it's smooth as butter. Then I put it back on the truck and try and start it. Its a horrible grind and nothing. Doesn't wanna move.
I got a pretty good video of it running. I had the firing order wrong on the 4 and 6 cylinders but it's fixed. So in the video, you see it rock and I'm pretty sure that's why. After I fixed it. That's when the dreaded, soul-sucking, bloodthirsty, flesh-eating, wanting to make everything in its path hell starter gave me the big one.
