2.8 V6 "Spacer" between Carb & Intake
Bronco648
102
Chicago-land, Illinois
XL
2.3
15"
I am putting the drivetrain back into my '85 RCLB. The 2.8 V6 has a piece of cast & machined aluminum between the carburetor and the intake manifold. The vacuum 'tree' and the EGR valve connect to this.
I need the gasket that goes between this piece and the intake manifold but have no idea what it's called and therefore, cannot source the gasket.
TIA
85_Ranger4x4
17,827
SW Iowa
FEL-PRO 60564/VICTOR REINZ 711432600/MAHLE G25701
Rockauto has them under "carburetor mounting gasket" if nobody local can cross them.
fastpakr
2,832
Roanoke, VA
If you look it up at Rock Auto, it lists the 'carb to spacer' gasket and 'spacer to manifold' gaskets separately.
Bronco648
102
XL
2.3
15"
Thanks guys!
4x4prepper
216
Atlanta
After finding cracks in mine, I eliminated my spacer and EGR.
19Walt93
4,465
Canaan,NH
351
3"
235/55R16
By the way, it's the EGR spacer.
Bronco648
102
XL
2.3
15"
What did you do to cover the exhaust port, in the intake manifold, that fed the EGR valve?
fastpakr
2,832
Roanoke, VA
You can buy or make an EGR block off plate.
Bronco648
102
XL
2.3
15"
I thought that was just the ~1" x ~4" plate that blocked off the two passages where the EGR valve was attached.
4x4prepper
216
Atlanta
I forget, it was 6 years ago? I might have just blocked it off with the carb base gasket, I would have to check my rebuilt 2.8L. I think I did them both the same way. Pictures of my carb set up. I lost the info on it, I think it is a 2150 carb from a 1974 or 1978 Pinto or Mustang II with the tube from the exhaust manifold to feed hot air to the pull off.
Bronco648
102
XL
2.3
15"
Thanks for the pics!
