johnnyboy110
- Nov 8, 2009
- 2
- Ford/Jeep
I've had this truck for about a year now and it was running great. All of a sudden it runs like poo. Down on power and it won’t rev past 3000rpm. It seem ok until it gets close to 3000 rpm. The truck starts up every single time. If you free rev it, it will sometime stall at idle. If it doesn’t stall then it runs rough for a bit then smooths out. Fuel pressure is good(65-72psi) and the pump and filter have been replaced. I checked spark and all 8 are firing. There are no codes and everything seems to be fine on live data. I checked the air filter and exhaust system for clogs. No probs there. I even cleaned the mass air flow sensor. I attached a video of some of the parameters. Not sure if it will come though.
