Shit I read the article sooo how do I install this pats stuff
You don't, IMO you would be better off getting a computer(ECM or PCM) from a '98 3.0l(non-Flex Fuel) with matching transmission.
'99 was the first year of Ranger getting PATS, and it would have PATS type B with separate PATS module above the glove box.
VEHICLES WITH PATS TYPE A, B, OR C SEND AN ENABLE MESSAGE TO THE PCM IF THE PROPER CONDITIONS ARE MET. THE PCM THEN ALLOWS FUEL INJECTOR AND FUEL PUMP OPERATION. THE PROPER CONDITIONS ARE: 1) A VALID KEY READ FOR PATS TYPES A, B, AND C, AND 2) PROPER PATS-PCM INITIALIZATION FOR PATS TYPES B AND C. REFER TO CHART FOR DETAILS ON THE REQUIRED INITIALIZATION.
SOME VEHICLES WITH PATS TYPE B OR C MAY INCLUDE A STARTER INTERRUPT (SI). THESE VEHICLES DO NOT NECESSARILY HAVE TO EXHIBIT A NO CRANK SITUATION TO CONSTITUTE A PATS RELATED NO START.
To add the PATS you need the module above the glove box and the loop around the key switch that reads the PATS key, and you also need the PATS key from that 3.0l vehicle and key cylinder so key will work on new vehicle................
Also anti-theft light on dash, not sure 2.5l has that or not
IMO, non-PATS computer would be better, but if you have the donor vehicle handy, and PATS keys for it, swapping the PATS equipment would be free
Reason for '98 PCM is because it will have the higher fuel pressure software, if it is different, I think '95-'97 had return fuel system, pre-'95 uses a different PCM altogether so won't connect to existing harness.
Non-Flex Fuel because truck won't have the fuel sensor so CEL would come on.
The PCM runs the automatic transmission if so equipped, and if you use an automatic trans PCM on a manual trans vehicle it will work but CEL will be on all the time, which some don't mind but if there ever was a 'real' reason for CEL coming on you wouldn't know it
