2.5L ('98-'01) 2.5 starting issues
cking
nevada
ford ranger
i turn the key and hear the fuel pump hum and turn the key to start and just cranks over . this only happens once and a while . turn key off then back on and it fires right up . is this fuel related or ignition switch related?
franklin2
1,758
Virginia
Pull the codes and see if you have any serious ignition codes in the computer.
cking
nevada
ford ranger
just had it smoged would that have came up then?
franklin2
1,758
Virginia
Not necessarily. If you can get it there, most of the parts stores will scan it for you.
tomw
46
lima bean
vertical and above ground
When you have the problem, you may want to check for voltage at the coil. A worn out ignition switch may be making intermittent contact in the actual electrical part, and with no voltage, no ignition. If you can wiggle the key when the engine is running, and cause it to stall or misfire, the switch becomes more suspect.
tom
tammyleigh
new mexico
ranger xlt
i had same problem turned out to be weak fuel pump.i had to cycle the key a few times
DCman
14
Poulsbo, Washington
Ford Ranger XL
2.5 (4 Cylinder)
P205/75-R14
tammyleigh
new mexico
ranger xlt
yes it was the factory pump that came new with the truck.
DCman
14
Poulsbo, Washington
Ford Ranger XL
2.5 (4 Cylinder)
P205/75-R14
Thanks Tammy. =)
