Bunger317
- Jan 3, 2023
- Reaction score
- 6
- Location
- California
- Make / Model
- Ford Ranger
- Manual
I recently picked up a 2000 2.5 manual ranger. Seemed to run great on the test drive. Motor has 197k on it and has reciepts for a rebuild at 176k. First day I drove it to work I let it warm up in the driveway while I made my lunch ran fine to work. Leaving work it didn't have time to warm up and once I got to the second stoplight and came to a stop it started idling horribly shaking vibration almost stalling. Had to crack the throttle to keep it running. Once it got to full operating temp it smoothed out and was fine. Does it everything single time it's started from a cold dead sleep. I've done plugs wire fuel filter pcv valve. Test egr by sucking on it. Iac looks new. Cleaned it anyways. Cleaned maf and map sensors. Can't seem to find a fix for this. I've never owned one before so have nothing to base it off of but it seems pretty under powered. Checked compression and got 150 on all 4 cylinders on a cold motor. Could it be a timing belt issue? It looks original. Possible leaking valves? Never had an issue like this and I'm baffled.
Also, mileage appears to be complete garbage. Fromwhat I've calculated im
Getting 14-17mpg.
Getting 14-17mpg.
