2.3L SOHC swap to 4.0L SOHC?
EnzoSZ
10
France
Ranger Splash
Hi guys,
I'd like to have your opinions and advices over swapping my ranger 1995, 5 manual M5OD-R1 gearbox, 2.3L SOHC for a 4.0 SOHC from an explorer.
I'm in france, got an imported Ranger from Canada, and a friend of mine, found me a complete 1999 Explorer, 4.0L SOHC, with a dead automatic gearbox.
Does anyone done a swap like that? I know sometime there is problems with OBD1 and OBD2, but my ranger and the explorer are OBD2, so should be ok.
There is huge modofication to do for the engine mounting point? Possible to put my gearbox on the 4.0?
Thanks
Enzo
Rock Auto 5% Discount Code: 32B05A80BF19AF Expires: July 1st, 2020
JOLENE_THE_RANGER
Active member
108
long beach, ca
1995 ranger 4.0 ohv engine mounts will allow you to mount the 4.0 sohc into your truck. im not sure about your flywheel. the 4.0 has a 8 bolt pattern for mounting the flywheel to the crank. if the m50d does mount to the 4.0, it wont last very long.
EnzoSZ
10
France
Ranger Splash
But I have the 2.3, don't know if there is any difference with the 4.0 ohv ^^
Well-known member
1,655
No, the 2.3l SOHC Manual transmission will not fit on a 4.0l engine, and no adapters
The M5R1(M5OD-R1) has an integrated bellhousing, can't be switched, so these transmissions were made specifically for 1 of the 4 Ranger engines used from 1988-2011(leaving out the 2.9l)
2.3l/2.5l SOHC Lima, 1988-2001
3.0l Vulcan, 1991-2008
4.0l OHV or SOHC, 1990-2011
2.3l DOHC Duratec, 2001-2011
None of these 4 versions of the M5R1's are swappable between engines sizes or between the two 2.3l's used
The 2.3l Lima engine was used in the 1983–1989 Ford Sierra sold in Europe
The 4.0l OHV or SOHC is a Cologne engine design so its bellhousing pattern is the same across these Cologne engine sizes
2.8l
2.9l
4.0l
Ford Sierra and Scorpio, European sold Fords, both used these engines, so a manual trans from one of these would bolt to the 4.0l SOHC from the explorer
You do need to swap over the explorer computer and wiring harness to the ranger
There is an issue because explorer computer will have software for an automatic transmission and you won't have one, so it will turn on the CEL(check engine light) and it will stay on, forever, unless you find a programmer that can delete the automatic trans software from the computer
And then there is PATS(passive anti-theft system), 1999 explorer will use a transponder key, the key in the ignition needs to transmit a "known" number to PATS module or the computer will not turn on fuel pump or fuel injectors
If you get a "working key" with the explorer then you can just put the key in the "reader" and tape it in place so with key ON the PATS sees the correct number and computer will allow starting of the engine
PATS can also be deleted from the computer by a programmer
EnzoSZ
10
France
Ranger Splash
Damn what a shame..
JOLENE_THE_RANGER
Active member
108
long beach, ca
I know. im saying those are the engine mounts youll need to get to be able to mount the engine in your truck
EnzoSZ
10
France
Ranger Splash
EnzoSZ
10
France
Ranger Splash
2.8l
2.9l
4.0l
By the way, Thanks Ron for all thoses informations, they will really help me!
Now I know what I can look for!
EnzoSZ
10
France
Ranger Splash
Hello, hello!
Got some news for the swap. The Explorer I saw as been sold so it's dead for that one, and it's daaaaaaaaamn difficult to find parts here in france, but I found an other one, complete, with automatic + one manual gearbox, with axles, and some stuff for 2000€/2165$. I think I can have a better price when I'll talk with the guy.
My biggest question now is about the harness. I just need to remove the motor harness and computer from my 2.3, and plug back the 4.0 harness/computer? It's plug and play?
I think I will take the counter from the Explorer, as they have the same shape.
Does the engine mounts from the explorer can fit the Ranger?
I'll be back with some more question when I'll have more informations about the Explorer (year, general shape etc..)
Thanks
Well-known member
1,655
Year of Explorer matters, only the 1994-2001 will work, 2002 and up were different
PetroleumJunkie412
2.9 Mafia
3,756
Pittsburgh, PA
2.9l Trinity
2.9 DOHC out of a granada is a semi bolt in... You may need to drill a d tap the engine mounts, but the bosses are there.
It'll rip the crank out of that sohc.
EnzoSZ
10
France
Ranger Splash
So I got some news from the seller.
Well, it's not one explorer but two ahah! One Sohc, automatic, complete, and one Ohv, manual, he remove the motor.
The SOHC is from 1999 and the OHV from 1996.
The manual is AWD, so with the transfert box... I guess it's an other problem te take in consideration?
Well-known member
1,655
Yes, that is a problem, the AWD
AWD transmissions can't be used as is in a 2WD, the AWD transfer case will "roll" even if manual trans is in gear with engine off, it uses a viscous coupling so BOTH front and rear drive shafts need to be connected to a differential or it will "roll" when Parked on even a slight hill
You could use E-Brake religiously and use the manual trans with AWD transfer case and shorter rear drive shaft
You can convert the M5R1 4x4 trans to 2WD with new output shaft and tail shaft housing, but its a bit of work(disassembly/reassembly) and parts to do it may not be handy in your location
EnzoSZ
10
France
Ranger Splash
And is that possible to take all the transmission parts, and pass the 2WD to AWD?
I had the idea to take the rear axle cause in any case, it's the 8.8 so a bit stronger
Well-known member
1,655
Not sure what you mean by "pass the 2WD to AWD"?
You are not likely to hurt a Ranger 7.5" or 8.8" unless you put on 33" or larger tires
The rating for both is 2,750lbs, thats how much weight that either can carry
The Explorer 8.8" is rated at 3,200lbs because body was heavier in the rear of an SUV
So not really needed in a Ranger unless you will be running very large tires and then that comes down to the larger diameter axles, not really the diameter of the ring gear
Using the Explorer rear end in a Ranger requires cutting and welding of the spring perches and shock mounts, so not a simple bolt in swap
Info here on that swap: https://www.therangerstation.com/tech_library/Explorer8_8.shtml
