2.3litersOfFury
- Jan 12, 2013
- 0
- ford
- Engine Size
- 2.3
First time posting on here and new to the forums. sorry this will be abit lengthy
Bought a 1988 ford ranger 2.3 5 spd about a year ago (from a quite shady guy now that i think about it) with a promise that only the timing belt had snapped. one long list of parts and more money than i ever wanted to spend later and it still hasnt made its successful maiden voyage. At this point its about ready to head down the hill and into the creek.
What i am now having issues with ( which i am in dire need of help) is when i start the truck it will fire right up no problem. then it will climb to about 3 grand and slowly even out to about 950 rpm or so and smooths out. once i hit the gas it will "bog out" until i let off the gas then it will climb back up to 3000 rpm untill it comes back down to normal idle. when i put it in gear it will instantly die as soon as i even feather the gas and clutch.
i pulled the codes on it (obd1 system) and i pulled a code 95 which is an infanite ground resistance in the fuel pump curcuit. found a bad ground in the sending unit ( wasnt grounding to the tank and frame) so i replaced that but it made little to no difference.
so please if anyone as any suggestions or had a similar problem it would be extremely appreciated
