- Aug 10, 2007
- 3
- Norco, CA
- Ford Fiesta
- Engine Size
- 1.6
- 2WD / 4WD
- 2WD
- Tire Size
- 185/55-15
- My credo
- #DontFollowJosh
Bringing it to page 2.if you dont understand how a system functions for yourself, you really shouldnt mislead others by trying to explain it.
the EGR system has nothing to do with burning unburnt hydrocarbons...the converter will take care of that (and has been since the 1970's).
the EGR system is designed to reduce the production of a pollutant called nitrogen oxide (NOX), which only forms in combustion chambers over a certain temperature. the EGR system prevents their formation by lowering combustion chamber temperatures.
exhaust gases are inert, meaning they do not add any fuel or air to the combustion chambers, all they do is take up room. since they are cooler than the combusting a/f mixture, they provide a lower combustion chamber temperature.
i can hear it now: "but mr sludge, doesnt the exhaust gas taking up room mean i have less room for air and fuel, and thus, less power from my motor?" no. the lower combustion chamber temperatures mean that the ignition timing can be advanced further than on a non-EGR engine, thus making up for any power lost due to exhaust gas presence in the chambers.
furthermore, all EGR operation is shut off during wide-open throttle...meaning even if the EGR system did cost you power, it wouldnt effect peak power.
as was mentioned, your computer is programmed to account for the EGR systems presence (primarily in the form of advanced engine timing). disabling the EGR on an engine programmed to run with it will cause a number of drivability concerns including, but not limited to:
-knocking/detonation - this can be fatal for a motor, leading to broken pistons, rings, and connecting rod bearings.
-lower fuel economy.
-rough running during cruise speeds
-check engine light
-failed emissions testing
-decreased power output
as was also mentioned, removing the EGR system is highly illegal. in fact, its against FEDERAL law to tamper with or disable any factory equipped emissions devices, regardless of wether or not you have emissions testing and/or inspections in your area. if your within the borders of the united states, your in violation of the law and the fine is heafty.
People assume that no testing=no laws.blueovalboy...as i said, tampering with emissions equipment is illegal in all 50 states, regardless of if you have emisions testing or not. you may or may not get caught, but why risk it when your likely to cause damage and drivability problems by removing the egr anyway?
Do even know what is in air? 78% of the air that is going into the engine is mostly leaving unchanged, because it is an inert gas. That is why people run nitrous oxide systems; displace the 21.8% oxygen with about 30%.i mean its got to help with carbon build up on valves and my truck runs on fuel fire and air not fuel fire and varis gasses that the government dosnt want in the o zone
Do you even know what NOX emissions are?
Isn't that way carburators are better?because you dont understand how the EGR system functions?
You mean like gasoline? Carbon gets in the engine from improperly burned gasoline carbon chain, not from an EGR.but why shove carbon into my engine
'79 302? I am sure it was in peak operating condition being how many decades old?see i ran into the same problem you did with you escort with my 79 302
If you displace the oxygen, the the fuel will be corrected. Otherwise you would be driving around everywhere with a rich mixture, which is great for emmisions and CAFE standards.Incoming exhaust gasses do change the a/f mixture in that the gas takes up space that could be used for more a/f mixture, plus the heat from the exhaust causes the incoming oxygen to be less dense, hence less efficiency.
Going back to the good post on page one, the system is off at WOT, so there is no air warming, no inert gas, just fuel available efficiency.
Less power at less throttle, where you are not demanding it.It "somewhat" compensates. But, here again, one size does not fit all. In many, if not most cases, the egr is a trade-off, a little less power for more emissions control.shady
He thinks he is getting hot air at WOT. Someone didn't read your post.see my original post.
the EGR's whole purpose in life is to LOWER combustion temps. removing it will raise combustion temps.
