On to more progress.
the MT82 trans from the Mustang has a remote shifter that sets pretty far back, fortunately there is a company called MGW that makes custom shifters for these specifically for swaps. The main benefit is moving the shifter forward 6-8 inches from factory mustang location, the second benefit is that it bolts solely to the transmission and improves the shifting issues that the mt82 is known for.
I had to do some extra cutting in the trans tunnel to make it fit but it turned out good and is in a comfortable position, this is their 4.5 in version.
With the shifter and transmission tunnel finished, it's on to the drive shaft. Having used the front half of the Mustang drive shaft I needed a custom shaft for the rear. I went with Tom Woods drives shafts and pleased with the results.
Next step is the Custom instrument cluster, I wanted a factory look but had to go with aftermarket tachometer and speedometer to make everything work. I purchased Autometer gauges and proceeded to cut up the factory cluster so that it would fit. the only factory gauge I would be using is the fuel gauge, temp and oil pressure will be monitored using the COBB tuner.
This also require modifying the wiring on the cluster and ranger, the tachometer eliminated one of the main plugs so I had to attach some wires to the printed circuit board and use Deutsch connectors for the new plug.
I am Super happy with how the cluster turned out, has the exact look I was going for in my head.
With the interior mostly finished its on to the engine bay to work on some of the intake routing. There is a tight fitment between the air box and turbo so it required me to make a custom pipe from a bunch of pie cuts out of a 3.5in aluminum tube. I cut a bunch out on the band saw and then stacked them up to make a tight compound bend. I then proceeded to fully weld all the joints, grind the welds down and polish the aluminum.
I also had to make a custom sensor block for the air intake temp sensor, just used some scrap aluminum and the drill press.
With that completed I moved to installing the custom alternator relocation bracket, my second revision as the first had some dimensional issues.
this locates the alternator to the same position as the ac pump as the alternator interfered with the steering box.
And the last thing for this Post is the Custom traction bar, I didn't like the options currently on the market so I designed my own traction bar set up. Pretty basic, attaches to top of axle leaf mount and runs forward to the frame above the front pivot of the leaf spring. Its up and out of the way and prevents any axle wrap.
To locate the front mount I set the suspension at ride height with a ratchet strap and used a laser level to line it up.
I positioned the front bracket over the top of the leaf spring pivot point in order to reduce any binding in the suspension travel. With it tacked in place I set up my bushings and cut the tube to length. Once I was happy with the results I welded it all up and gave everything a shot of black paint.
So that is it for this update. I am currently waiting for a custom radiator to be built and some parts to show up so that I can start on the intercooler. Truck is really close to being done, I plan on having it on the road by mid June.
