1st gen steering column after 3inch lift— not long enough despite extension?
neinnein_nein
30
new york
ford ranger
soon-to-fire up 2.3 turbo lima
3!!
I put in the 3inch body lift from Jeff bronco graveyard while doing a swap, put in the extension and the car hasn’t moved since because I’m still working on the engine, but as of now it’s 2 inches short.
you guys know if there’s a way to pull on the upper shaft? It ends at the brake booster which even lifted seems suspiciously high.
Should I put a bolt in it and hammer downwards?
You can see the seem between extension and original column on pic 2 just below the chrome bolt..
51668
51667
No members online now.
