1st Gen rangers have 2 fuel filters??
svtcards
Active member
29
Lyman maine
3'' front 4''back
I'm in the process of replacing my fuel system and I noticed there's 2 fuel filters.1 cartridge cannister type and 1 inline type behind driverside motor mount.are these both needed?I read I had to relocate the inline one for header clearance just wasn't sure where to relocate it or if it's really needed at all.
Rock Auto 5% Discount Code: 32B05A80BF19AF Expires: July 1st, 2020
bobbywalter
TRS Technical Staff
993
woodhaven mi
FORD mostly
BIGGER
sawzall?
Sometimes.
I just throw all that brittle crap away..from the high preaaure filter back to the tank.. upgrade to a mustang pump in place of the stock low pressure unit...and run the single inline.
Cleans it up and simplifies the whole deal.
gaz
Active member
46
Wa, Bremerton 98310
2.9l
svtcards:
Actually there are 3, there is another before the pump in the tank.
When I was chasing a fuel delivery issue I learned about the 2nd external fuel filter. I changed it to know conclusively what was going on. It turned out that it was in good condition.
bobbywalter
TRS Technical Staff
993
woodhaven mi
FORD mostly
BIGGER
sawzall?
Yeah....the sock rips and jams the pump, or plugs off too.
Use a new sock. But I put that under the common sense...ass u me catagory.
svtcards
Active member
29
Lyman maine
3'' front 4''back
Sometimes.
does a mustang low pressure pump fit in a 1st Gen ranger tank?if so what yr mustang are we talking about? So oem high pressure ranger pump with the low pressure mustang pump? 1 inline fuel filter only?is this correct?
bobbywalter
TRS Technical Staff
993
woodhaven mi
FORD mostly
BIGGER
sawzall?
High pressure pump.
You use say....a 90 mark 7 or mustang fuel pump in your carrier.
Run new line or a later model line from the sender to the rail filter and remove all of the other stuff ..HP rail pump and all. Keep it for later use trouble shooting...or what have ya...
Get efi hose and clamps and reuse the ends you have or go all new.
Run all new fresh wire from inertia switch.
Clean and simple.
svtcards
Active member
29
Lyman maine
3'' front 4''back
I was told the stock efi system from my 1st
gen ranger could support an efi 302 no problem.is that not the case?I was just planning on replacing low-pressure in tank pump with new one. replace high pressure pump in frame rails with new one.replace all fuel lines. which I already purchased Russell braided stainless lines -6an and Russell fittings.just wasn't sure if all the fuel filters were necessary.now I'm not sure if I should look into what your saying now or not?that 86-92 mark 7 pump is that a high pressure or low pressure pump?and would that fit my tank without any modifications?
alwaysFlOoReD
Forum Moderator
1,447
Red Deer, Canada
'91, '94, '80
Ford, GMC
4.0,4.0,350
It would be a high pressure pump.
What he is suggesting is to replace the low pressure in tank pump with a high pressure unit, and getting rid of everything from the tank to then last fuel filter. You would save money. And JIC fittings are a hell of a lot cheaper than Russell fittings and do the exact same thing...just no bling.
svtcards
Active member
29
Lyman maine
3'' front 4''back
Kinda what I thought he meant.i wish I didn't already spend the money on the oem in tank and in frame pumps already.i guess I ll just use what I have since monies are already spent.wasn t sure if the mark 7 pump even fit in my tank but sounds like it does.thanks for the help everybody.this is my 1st engine swap in anything ever so some of the termialiagy u guys use it harder for me to understand.hopefully I can get through it.with some help from the ranger station also of course.lol.i will also b looking into jic fittings as well.russell fittings r pretty expensive
alwaysFlOoReD
Forum Moderator
1,447
Red Deer, Canada
'91, '94, '80
Ford, GMC
4.0,4.0,350
I've never done this particular pump swap. It sounds like you would swap out the pump into the stock pump housing that holds the low pressure pump. What he called a frame.
svtcards
Active member
29
Lyman maine
3'' front 4''back
That makes sense.since I already bought the in tank low pressure and on the frame rails high pressure pumps ranger oem types already from rockauto a few mths ago i mind as well use it.by the time I pay to ship items back plus restock fee would make no sense for me not to use it.if it was bought locally I'd be driving there tomorrow and buy the mark 7 one.i LL just use 1 fuel filter after high pressure pump get rid of cartridge cannister shit filter and run that b*;+ch.thanks again man.im sure I ll have more questions.stay tuned.
SenorNoob
Well-known member
38
Middle Tennessee
Wouldn't using just a high-pressure in-tank pump with the smooth bottom tank mean you'd potentially be fuel starved on a long hill with less than half a tank?
alwaysFlOoReD
Forum Moderator
1,447
Red Deer, Canada
'91, '94, '80
Ford, GMC
4.0,4.0,350
The canister type "fuel filter" is actually a fuel reservoir. Some did have filters but not all. I'm not too sure when they stopped using them, maybe when they went to high pressure in tank pump?
svtcards
Active member
29
Lyman maine
3'' front 4''back
Is it necessary either way?
