- Jan 26, 2017
- Reaction score
- 10
- Make / Model
- Mazda
- Engine Type
- 2.3 (4 Cylinder)
- Manual
- Tire Size
- Michelin LTX M/S P235-75R15
The stalling or wanting to stall issue is intermittent. It only happens when coming to a stop (while winding down to idle.) It will mostly almost stall, but picks back up at the last second before stalling and if I have a load (like A/C or while turning) it will stall. It always restarts without issue. FYI: Battery change (which was due) had no effect and the near stall and stall occurs still with new batt. FYI: MAF cleaned and PCV cleaned.
The engine seems to hunt around for the a stable idle at times and vaguely wavers and does not set hard at one particular RPM. I have no engine light warning and the issue was occurring very intermittently before the catalytic converter and oxygen sensor replacement and still occurring after that. I suspect I need to clean the throttle body, but is there anybody else who runs across this?
Thanks in advance and thanks for being here.
