mykle
- Jan 25, 2023
- Reaction score
- 2
- Location
- Portland, OR
- Make / Model
- Mazda B3000
- Manual
Hi all, first time here ... My '99 B3000 beater truck went on strike a week ago. It's never had trouble starting before, and now it refuses to turn over, I don't even hear a click. So I got out a Haynes manual and started checking all the systems ...
Battery: reads 12 volts. But I tried jumpstarting anyway, and still nothing.
Fuel pump inertia switch: was not tripped. I tripped it, saw FUEL PUMP light on dash, reset it. Made no difference.
Ignition switch: only a year old, and when I turn it the dash lights blink and the radio goes off, and the battery voltage drops a tiny bit. I think it works.
Clutch position switch: I unhooked it and wired a bypass. No change.
Starter relay: Tested, works. (I swapped it with the blower relay & the blower still works.)
I disconnected the battery leads for 60 seconds to reboot any computers that might be hiding in there. No change.
My wiring diagram suggests that there's an optional RAP module, but internet seems to think that's on the fancier models with power doorlocks. This truck is pretty vanilla, has no power anything. If there is a RAP module on this B3000, I can't find it. But the wire leading to the clutch position pedal is white/pink, and the wiring diagram suggests those colors come from a RAP module ... maybe there's some other antitheft device at work? I don't know where to start looking for that.
I haven't inspected the starter solenoid under the engine yet. But like I said, the truck was starting strong every time until it changed its mind a week ago. And now I hear absolutely nothing when the ignition turns. Would a starter solenoid die so suddenly, silently all at once like that?
Is there something else I can check? Are there other pieces of this circuit that might not be on my wiring diagram? I'm out of ideas, but I dread having it towed. Any advice appreciated!
