1999 2WD 2.5L 5 speed manual (M5OD-R1) stuck in 4th gear
Its not a hard trans to tear down by any stretch.
But if you can get a whole trans cheap that may be the way to go. You will probably have less into a whole unit from a U-pull yard than into buying just the pieces you need new.
8,369
There are some specialized tools needed and at least one bearing needs to be pressed in.
Used M5OD-R1 is not a bad gamble, contrary your current experience, lol
But..............M5OD-R1 is a model number not what it fits
An M5OD-R1 from a 3.0l engine will not work with your 2.5l, nor would one from a 4.0l engine
Fortunately your 2.5l SOHC Lima engine is a stroked 2.3l SOHC Lima so they share same block and transmission
Rangers used the 2.3l Lima with M5OD-R1 from 1988 to 1997, then with the 2.5l from 1998-2001(mid-year)
In 2001.5(mid year) Ford switch to the 2.3l DOHC Duratec engine, no relation to Lima, so trans from this engine will not fit your engine
Most 1988 to 2001 M5OD-R1 from 2.3l or 2.5l Ranger will be 2WD transmission, 4WD transmission is different, it can be converted but best to just used 2WD trans
1994-1997 Mazda B2300 2WD used same transmission, as did the 1998-2001 Mazda B2500
If you can find one from a 3.0 2wd you can just throw all the guts into your 4-cyl case. Not that hard to do.
Junk Collector
Truck of Month
4,791
Rapid City SD
Dang it. You can replace whatever is broken inside yours but you need all those parts plus a bearing kit - probably cheaper and a whole lot easier to find a junkyard or rebuilt trans.
FWIW you do not need a press unless you're removing gears from the shafts they're on - not necessary usually. The bearing Ron is talking about can be pushed on with a piece of pipe and a hammer. I have a press and did not use it when I rebuilt mine. You do need a 55mm or 2-3/16 wrench or a big pipe wrench to tighten the output shaft nut, a depth measuring caliper and feeler gauges. It's pretty straightforward.
ericbphoto
Overlander in development
16,584
Wellford, SC
3.0L
6"
Judging by those pictures, I'd say he has a gear to press off/on.
jpark6491
Illinois
2.5 L4
I think I am probably going to go the replacement route after pricing some parts. There is an LKQ - pick-your-part place about an hour from me and they have a manual transmission listed at $100 + $30 core charge. I also might hold onto the old transmission in case I need extra parts. All of the other gears look decent but when I drained the fluid out there was very little that came out and it was very black so not sure.
What would have caused the input shaft gear to be destroyed like this? I know that the prev owner replaced the clutch himself, would incorrect installation have contributed to it?
The low fluid is the culprit.
That gear is hooked right onto the engine, if it starts to overheat and its gonna start losing teeth. And it doesn't get well lubed when the fluid is low. That's what that little trough is for, it catches fluid splashed or flung up against the top of the case and directs is to the input gear. If the fluid is low, or not splashing, it has nothing to work with and can't get the needed fluid to the gear.
8,369
+1 ^^^
Or the wrong fluid
M5OD uses ATF, yes automatic transmission fluid in a manual transmission
A shop or DIYer might use Gear Oil which was used for 100 years in manual transmission and differentials
Its too thick and won't lube/splash upper input gear
jpark6491
Illinois
2.5 L4
That all makes sense then, it's a shame that they ran it out of oil. I certainly won't be making that mistake. The new tranny is going to be treated right. (y)
Yeah, this whole thing reminded me, my B2 has been shifting like it might be low. I should check on it this week.
jpark6491
Illinois
2.5 L4
So things at the junk yard didn’t go as well as planned. The trans that is in the truck there is held in by two frozen, very rounded off bolts. I fought for a day and a half on it...unfortunately limited power tools there and no torches allowed.
Now I’m on to plan B. I did find a 1995 trans with 130k miles on EBay about 2 hrs from me for $150.
Other option, I found this item on EBay as well.
jpark6491
Illinois
2.5 L4
What website/source does everyone get their transmission parts from? I was just looking a few and Cobra Transmissions seems like they had some quality parts and customer service.
I use Cobra for pretty much anything transmission related, unless they don't have it. Haven't had a bad experience yet.
I'm getting read to rebuild my own M5OD, just waiting for space in the garage to do the work, and I plan to order my bearing and synchro kit from them.
