DavidG
- Jun 17, 2020
- 0
- Seattle
- Ranger 4.0 4x4
Hi everyone. I bought a 1998 Ranger 4.0 XLT 4wd 5sp about 2 weeks ago and have a question about the temperature gauge. The gauge works, but when cold, the needle sits about 3/16 of an inch below the lower line and, when warm, sits about 1/4" above the lower line.
I think the overall movement is probably correct and I think that if the needle started out at the lower line, that it would probably be halfway between upper and lower when the engine is warm.
Can someone please tell me where their needle sits when cold?
Also, does anyone know if there is a way to adjust the gauge so that the needle is in the correct position when cold? All may cluster lights are out and so will be removing the instrument cluster to replace - in case there is a way to change where the needle rests when cold.
Thanks for your help.
David
David
