Bitwise
- Dec 13, 2021
- 7
- Canada
- Ford Ranger
Recently took a 2000 km trip this February the day after a 50cm snowfall and through -26 C weather through much of the journey in my 1997 Ford Ranger 3.0 V6. Only issue was at one point the throttle cable got caught and stuck half open. Sometimes when it's cold it sticks at just a little bit of throttle but quickly tapping the pedal fixes it.
This time I couldn't unstick it so I had to pull it over. I had some WD40 with me so I sprayed that on the cable from the top and the bottom, and through a crack in the sleeve over the cable about halfway down. After working it back and forth manually for a while it unstuck and I was on my way. The WD40 fix worked fantastic for a while but it gradually started sticking a little like it usually does. I'd like to take care of this just in case. Looks like they don't sell new cables anymore for my generation. Anyone know if one for a newer generation can be made to fit? Not too many of these in the junkyards around here. I might be able to find one, but since my cable isn't actually broken lubricating it properly might be the better option (and covering the crack in the sleeve). Anyone got any tips for how to best lubricate the cable?
Thanks!
Thanks!
