swolsky
- Mar 23, 2020
- 0
- Collegeville , PA
- mazda b2300
Okay i Will take and post picture of what needs to be done with these. They come in next Wednesday so probably next Saturday I will post.
I gotta say the tri-y headers are tight to the engine, these are great! My Dad and I had to bend the pipe out a little bit maybe 1/4in, not even, on both sides to clear the 164 tooth bell housing. These look like they flow a lot better than the stock 93 mustang ones. I will post pictures soon to show how they fit in my 97‘ b2300I think they fit in without cutting the frame the problem you are going to run into is the Tri Ys wont fit around the M5OD-R2 trans (164 tooth bellhousing) from what Ive read with out modifying the potion of the pipe near the collector.
Before you try to put it in the truck. Bolt the engine and transmission together and put your starter on before you put on the headers to make sure I am not wrong.
Take some measurements.
