cnord
- Nov 28, 2016
- Reaction score
- 2
- Location
- Lake Forest Park,WA
- Make / Model
- Ford
- Engine Size
- 4L
- Manual
When the fan is on I continually get hot air from the vents. Turning the temperature adjustment knob to cool (counter clockwise) does not change the temperature. If I listen carefully when I turn the temperature adjustment knob I can sometimes hear a slight grinding sound....not fan related, more like a baffle moving due to vacuum. Difficult to describe. Anyway, I took off the glove box to take a quick look for anything obvious.
So my question to all you gurus -- is the air blending (hot/cold) baffle in the heating plenum (the big black plastic assembly behind the glovebox)? Is there a way to access this? The book indicates I need to remove the entire interment panel to get access. Maybe, pull the and inspect that way. Ideas?
C -
C -
