Welcome to TRS
Well, there is only one thing that can increase engine RPMs, increased air flow.
You can add more fuel and all you will get is a too rich mix and flooded engine, lol, gas don't make a car go, air does.
So throttle plate or IAC Valve.
Now a '96 manual trans will have hold and shift RPM software, so if you are moving and shifting gears the RPMs should hold or increase a bit(no load with clutch pedal in) for a few seconds before dropping down if you keep holding clutch pedal in.
And RPMs should stay above 1,100 until speedometer is below 5MPH, that's another software add on.
These both lower emissions because RPMs don't drop down too much.
So throttle plate or IAC Valve, both control air into engine so both control RPMs.
Throttle plate would be easiest to check, strictly a mechanical device.
Check that plate isn't loose inside intake(throttle body), and that the Return Spring can still snap throttle closed quickly, hard to stop that air flow at 3,000rpm, need a good strong spring.
Generally feel the throttle opening and closing, smooth operation no binding or stickiness.
If you have cruise control disconnect that cable from throttle linkage and drive a few days that way.
IAC valve
"New" used to mean "tested and works"
"New" now means "you test it, we warranty it"
So don't put alot of trust in "new" anything anymore.
Since you replaced the IAC Valve did you do a computer reboot?
Swing by an auto parts store and have them read the codes, write them down, and then reset/reboot the computer.
IAC Valve is a "learned" control, takes a few days, drive cycles, for computer to "learn" new IAC Valves settings.
Vacuum leak, small one and near cylinder 4, could be causing Lean mix at idle.
Easy to test for
After engine is warmed up and idling, unplug IAC Valve, it will close and idle should drop down to 500rpm, or engine may even stall, either is good it means no vacuum leak.
If idle stays at 700rpm or higher then there is extra air coming in from somewhere, air is RPMs
