Suzonda
- Sep 9, 2020
- 0
- Maine
- Mazda B2300
- Engine Type
- 2.3 (4 Cylinder)
- 2WD / 4WD
- 2WD
1996 Mazda B2300 2wd 5spd, 4PIN MAF.
So over the past week I've noticed my lack of power has turned into NO power. (I can't even get above 64mph on highway in 4th, 5th isn't even an option). So I plugged in my Foxwell scan tool, it came up with a P0172 code, cleared it, then truck backfired to a stall. It took 4 tries to start it back up and it pinged and popped for about 45sec until it got to normal idle. The code came back, cleared it again, and this time it just died. I started it back up then I went into live Data and the MAF was reading a 7.34lb, I brapped the throttle, then it dropped down to .001-.000. I know that it should read anywhere between 2.3-2.7. I cleared out the code, then the MAF reading went all over the place. (Jumped between the values of .000-4.56lb) I have another PCM from a 1995 B2300 5spd 4x4 OBDII 4PIN MAF but I'm not sure if would work on this one since the gauge cluster didn't (Not related but it has different wiring apparently). THERE ARE NO VACUUM, SEAL, OR GASKET LEAKS. ALL EXHAUST FROM MANIFOLD BACK IS BRAND NEW FROM FORD. Does anyone have ANY ideas?
New parts Include ECT, IAT, IAC, TPS, Cam and Crank position sensors. I also replaced the entire fuel system. Brand new Delphi sending unit, new fuel filter, new factory lines, FPR, and Motorcraft Injectors. I tested the injector wiring, the timing is 10-15 BTDC at idle, 28-35 @2500-3200rpm.
