Lance58
- Aug 20, 2020
- 2
- Vancouver
- Ford ranger 2.3
Hi all, looking for some help on a 96 2.3 manual 2WD I bought recently.
Problem: When coming to a stop in 1st or 2nd gear the truck stalls.
Some back ground info:
Manual 2W ABS, no A/C
Truck runs very well, idles smooth starts fine cold or hot, slight smell of running rich and may lack a bit of power.
If I clutch in 3rd or 4th and coast to a stop it idles fine, only happens coming from higher revs.
Cold or hot start no black smoke and idles and runs normal, temp appears normal.
Note; Speedo not working even though I replaced the VSS, no CE light but stored code for VSS circuit.
I have done the following:
Fuel Pressure runs and holds at 30psi very little leak down
Changed IAC
Cleaned MAF
Cleaned TB
New Temp sensors gauge and water as well as t-stat
Cleaned and tested IAT Sensor
Plugs are nice shade of grey, no misfires
No Visible vacuum leaks or cracked hoses
Tested EGR, holds vacuum and opens and closes
Reset PCM
Thanks
Changed IAC
Cleaned MAF
Cleaned TB
Reset PCM
Thanks
