Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
It plugged in to my truck maybe it's a 94 but I could swear the computer came out in 9595 was the start of OBDII for the Rangers and a lot of other light duty Ford vehicles. 93 is still firmly in OBDI territory. Not only will it not work, it won't even plug in.
Did it start and run?It plugged in to my truck maybe it's a 94 but I could swear the computer came out in 95
So if it's a 94 would it work?Somewhere on the computer's label is a series of numbers and letters broken up into three sections. The middle section is 12A650. If the first two digits are F4 it's a 94, if they are F5 it's a 95.
An OBDII computer shouldn't even plug into your 93's harness.
Yes it is1990-1994 4.0l computer has 60 wire connector
1995-2000 4.0l computer had 104 wire connector
Do the math, lol
Yes a 1994 4.0l Ranger computer will plug in and work in a 1993 4.0l Ranger
Is it knocking/pinging or KNOCKING like a bad connecting rod?
So I originally had a computer issue and I was missing all over the board so I swapped in the computer out of a 94 Cimarron great for a while and then developed the ticking noise between 2000 RPM and 3000 RPM but doesn't do it under load or coasting just when you're barely on the throttleNot computer related
So whats the history?
Pretty hard to hurt the lower end on the 4.0l OHV, they normally go 400K+ miles
