blbzeckhart
- Mar 18, 2021
- Reaction score
- 8
- Age
- 48
- Location
- Mocksville, NC 27028
- Make / Model
- Ford Ranger
- Engine Type
- 4.0 V6
- Automatic
- 2WD / 4WD
- 4WD
Complete Engine Swap.
Re-installed same P.S Pump and Reservoir.
Truck runs great. Power steering hard as hell to move while driving.
Manual says turn wheel left to right several hundred times to work out air?
Lifted front end (wheels off ground), put in fluid and while running and cap of reservoir turned back and forth several hundred times.
Bubbles (air) present in fluid in resevoir but still never go away.
Is there a better procedure to get the PS to work right?
What is the best way to bleed the Power Steering Pump so it works correctly after it has been uninstalled and then re-installed?
Any suggestions or help would be so appreciated!
