Its actually pretty simple to add power to any vehicle, because there are only two ways to do it
Lighten the load, there is a "power to weight ratio", if you lighten the vehicle then engine can make it go faster and quicker
Increase the amount of energy engine can release, gasoline engines use 14.7:1 air:fuel ratio, this is a WEIGHT RATIO
14.7 pounds of air to 1 pound of gasoline
14.7 grams of air to 1 gram of gasoline
Ever wonder why fuel injectors are rated at POUNDS PER HOUR of flow, thats why
If you add more gasoline to an engine, you get a flooded engine, not more power
But you need to add more gasoline to release more energy...............
So you need to add more air, FIRST
A 5 liter engine has more power than a 4 liter engine because it can pull in 1 liter more air every 2 RPMs, so can burn more gasoline and release more energy
Cams allow an engine to pull in a bit more air every 2 RPM so more fuel can be added
Super or turbo chargers FORCE more air in so even more fuel can be added
So as said, pretty simple to understand what is needed, not complicated at all
Less weight to move
OR
More air to move that weight
OR
Both
