1994 Ford Ranger Rear Brake Problems
Buster78
Madison Indiana
I've got a 1994 Ford Ranger & the wheel cylinder went out on my. The problem I'm having is that the wheel cylinder takes a 1/4" brake line but a 3/16" brake line won't screw into the T. Could anyone please help me figure out what to do?
franklin2
1,758
Virginia
Usually the wheel cylinder takes a 3/16 standard fitting and brakeline, the tee takes a 3/16 brake line with a 1/4 inch fitting correct? The 1/4 inch fitting is a special fitting that has a 3/16 id but has 1/4 inch threads on the od.
You can go to the store and they usually have brass adapters like this. The link below has the Dorman number you can use at the store to see if they have one.
Eddo Rogue
2,502
Burbank,CA
Ranger 4x4
OHV
skyjacker front leveling kit
31-10.50R15
Get a brass adapter is the easiest option, but you have a few.
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Uncle Gump
Token Old Guy
13,454
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I moved your post over the the brake forum...
If the original line nut is savable... cut the line install the old line nut and double flare the line at the correct length.
