1994 Ford ranger air intake problems
Mikeosaji
9
Madison al
Ford ranger xlt
So after I put an aftermarket cold air intake on my truck it started to lose almost all rpms limes would press on the gas and barely get any acceleration. I never did reset my cpu in my truck, but does anyone else have a clue why it would do that?
Rock Auto 5% Discount Code: DE2235E7692E8C: July 5th, 2021
3,357
All fuel injected Rangers(1986 and up) have a stock Cold air intake, so you didn't install a cold air intake you just changed to a different cold air intake
No computer reset would be required
Did the MAF sensor get put back on?
The Ranger air filter and box had 200% of the air flow required by the engine, so filter could get pretty dirty before engine performance was effected
Are you using a smaller "cone" type filter?, if so remove it and see if power is restored, you can drive without a filter to test if that's the issue
And don't use "oil bath" filters, they foul up the MAF sensor
There is no real benefit in changing to a different cold air intake, except for looks, cause they can look way better than stock air plenums, lol
But they do need to preform at least as well as stock intakes or there would be problems
One tell tale of a problem, is sound, i.e. if you can now HEAR air being sucked in when you REV the engine, that means there is turbulence, so restricted air flow somewhere in the new system
Mikeosaji
9
Madison al
Ford ranger xlt
Yes the maf has been on it was very undrivabke I had to put the old one back on I was using a cone filter yes it was a shorter one not a long one. I just wanted to know what the problem was I took it off and don’t plan on using another one until I supercharge or turbo my truck
3,357
I would guess restricted air flow was the problem
Engines run on air with a little fuel added, but air is the major part
If you want extra power from an engine you give it more air, bigger cams, turbo chargers, super chargers don't add more fuel, they add more AIR to get more power
A 5 liter engine has more power than a 4 liter engine because it can use more AIR, 1 more liter of air
NOX(Nitrous oxide) injection adds more AIR
AIR is what makes an engine GO :)
