1994 Ford Ranger 4.0 v6 4x4 will not engage in any gear, revs in every gear
joshbrown21
So I went off roading and launched off a jump in my prerunner and cased the landing, I bottomed out my rear susspension enough to buck my rear wheels off the ground and nose wheely for a few feet. After that I went to step on the throttle to keep going but my truck would just rev as if it was in neutral. I stopped and restarted it and in every gear (Reverse, neutral, drive, 3rd, 2nd, and 1st) it would rev and not engage into gear. It is now in my garage and im stumped. My dad thinks it has something to do with the solenoids, but we are not sure. The driveshaft and the U-joints all seem to be fine and in tact. We dropped the transmission pan to scope it out and check out the solenoids. Does anyone have any idea what could be wrong?
Thanks
Does park hold the vehicle?
joshbrown21
yes, the linkage engages all the way down into the transmission from the steering wheel
ElectraRider
107
Colorado Springs Co.
Ford ,Ford
2.9 ,4.0
electronic 4 wheel shift or manual shift?
baddis
6
Avon,il
2014
4.0 Sohc 1.5 ecoboost
did the speedometer needle still move while it was reving?
Andy D
10
Marshfield MA
The Rat
4.0 OHV
to prevent Found On the Road Dead, Fix Or Repair Daily
This is just a wild @$$ed guess. The transfer case mode shifter, the electric shift has been jounced into neutral. Spongy as the Rat's frame is, I keep all 4 235s firmly planted :D
MikeyK
torque converter stripped out. Relatively cheap/easy to replace but you have to drop the trans. Happens in fords all the time.
You must have kept on the gas when the wheels lifted and caused a shock on the system when they came back down. (wheels spinning faster off the ground, hitting the ground, wheels moving faster than the truck and ground; something had to give)
wildbill23c
577
Southwestern Idaho
215/70-R14
Grandpa's 93 Ranger had the same exact issue. Well except it hadn't been jumped. Just the transmission one day decided to not work, and this was after about 13k on the rebuild of the transmission. I remember reading somewhere that these A4LD transmissions were notorious for this failure and had to do with the shift solenoids and valve body if I remember correctly. All I know is after the 2nd transmission failed within a year after the rebuild the whole truck went bye bye.
MastuhWaffles
11/2014 OTOTM Winner
69
Texas
4.0L SOHC
I need more sleep.
It is probably the torque converter, I've seen it happen before.
wildbill23c
577
Southwestern Idaho
215/70-R14
My grandfather's 93 Ranger when it did this, it had reverse for a while, and then even reverse wouldn't work anymore.
The shop did a complete rebuild supposedly, and put the original torque converter back in. AAMCO did the rebuild and said it was pretty common for either the valve body or the solenoids to fail in these transmissions. However, for AAMCO supposedly being such a great transmission shop they sure didn't prove it to me with a tranny rebuild and another failure within 13,000 miles.
MikeyK
bring it in for free diagnostic most local trans shops do this, but if it lost everything at once it is torque converter. The torque converter is what pressurizes the fluid, without pressure your transmission will not do anything.
^^Wildbill23c you say you still had some gears left and some did not work, YOU needed a rebuild, very different symptoms from loosing everything at once and loosing some gradually from wear and tear.
mikeluckey
joshbrown
Josh, this may sound dumb, but it happened to me, did you knock the transfercase out of gear when you hit.?? if in neutral, it won't work. I did that one time, my daughter riding next to me kicked it into neutral, and I didn't know it. Good luck!
