1994 Ford Explorer dash in 1988 ranger
rocketkart
32
Florida
Ford ranger
Any of you guys heard of any successful egr delete without throwing a code ? Only ask because I have the aftermarket headers and it does not have it Where I can hooked the EGR pipe back up on this 4.0 ohv
Junk Collector
4,704
Rapid City SD
rocketkart
32
Florida
Ford ranger
Junk Collector
4,704
Rapid City SD
Will the 93 ecm run the 94 engine?
Yes. The main difference is 94 will have a cam sensor and EGR, 93 could have any or all of those or none, 92 and older has none. 93 Ranger is safe, 93 Explorer is less safe.
FYI I put a 94 Explorer engine that had both into a 93 Ranger that came with neither and it worked perfectly.
rocketkart
32
Florida
Ford ranger
what about o2 sensor delete ?
Junk Collector
4,704
Rapid City SD
Not sure on that, I don't know why you'd want to? It is kind of a valuable tool to determine air/fuel ratios even with a custom tune.
rocketkart
32
Florida
Ford ranger
10-4 was asking because I’ll have to weld in some pieces to screw in the 02 sensors with the new headers. There’s no provisions for O2 sensors. Was just wondering. Thanks
Junk Collector
4,704
Rapid City SD
Oh, gotcha. You can get weld in bungs from most of the parts stores, that's what I would do. Actually that's what I did do for my V8 swap, IIRC the O2 sensors were in the Crown Vic manifolds I had that didn't fit my frame so I ended up using 70's 302 truck manifolds instead. I put the bungs in the Y pipe, worked great.
rocketkart
32
Florida
Ford ranger
10-4 appreciate it.
rocketkart
32
Florida
Ford ranger
Putting the new wiring in from the 94 Ford explore to the 88 ranger and I’m wondering do I need to take the abs brake stuff out of the explorer as well to put in the ranger or can I bypass all that ?
rocketkart
32
Florida
Ford ranger
Nobody knows anything about that lol
Junk Collector
4,704
Rapid City SD
You can bypass all that junk. Brake light might come on or it might not or the ABS light might come on. I would just pull the bulb.......................
rocketkart
32
Florida
Ford ranger
Making some progress but holy shit the wiring on this thing is crazy but I think I’m gonna make it
rocketkart
32
Florida
Ford ranger
Anyone have pictures of the vacuum diagrams, and the cruise control diagram ???
Kirby N.
March Truck of The Month
