1994 B2300 Hard to start when engine cold
B2300
California
Mazda
I have a 1994 2.3L B2300 stick (same as Ranger) with 330K miles. The problem is that it is hard to start when the engine is cold (take 3 to 4 cranking to start). Once I get it started and run for a while (meaning the engine is all warmed up), then I don't have any problem starting throughout the day. No rough idle, no CEL light, runs smoothly with A/C on, etc ...
I changed out sparks, sparks wires, coolant temp sensor, coil packs, fuel filter, fuel pump. I also cleaned IAC as well.
alwaysFlOoReD
Forum Moderator
3,418
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Rent or buy a fuel pressure tester. You should be getting around 40 psi at the fuel rail. That pressure should hold for months, so if it drops over night then there is a leak in the system somewhere. Ford's fuel pump will turn on for only 2 seconds if the motor doesn't start, so if there is no pressure to begin with it takes 3 or 4 tries before enough pressure builds up to allow the engine to run.
tomw
42
lima bean
vertical and above ground
To add a bit, you can cycle the ignition from OFF to ON, pause and let the pump run, and repeat a few times before trying to start the engine. If it then starts readily, you can deduce that the pressure in the fuel system dropped over time(or use a gauge if you want), and there is a leak. Possible non-odorous leak spots are the injectors, or the check valve or the fuel pressure regulator. Based on vintage, I think some had a check valve in the fuel pump assembly in the tank, and some in the fuel pressure regulator itself. If you have a returnless system(vintage based), the pump performs the check valve function.
tom
Craig0320
193
Mississppi
Break it right the first time. Fix it better the next time.
On top of the other items that have been stated to check. Do a compression check when it is cold. I have a chevy tracker in the yard and it has low compression takes 5 or 6 turns to build enough compression to start. Once it is warm and the rings are expanded it fires right up every time. Then on the next cold start 5 or 6 turns it fires up. I'm not to worried about because it is a hunting vehicle.
