Aty
- Aug 13, 2024
- 1
- Oklahoma
- Ford Ranger XLT
Originally my Ranger was in a no start condition where it would crank but no life from the injectors or sparkplugs. The original owner had already replaced the ignition control module and had had no success. When I got the vehicle I went ahead and replaced the wiring harness since the original was badly worn in multiple spots but to no avail. At this point I was pretty suspect of the main computer especially since it seemed to output different codes or sometime no codes. The final nail in coffin was when I found that the capacitors had burst and dumped junk all down the circuit board and even soaked into a few of the traces. With a new main computer I am still experiencing pretty much the same issues but with plethora of new codes and I think fuel injection. (The sparkplug reeked of gasoline when I pulled it out to test it after cranking the engine over.)
The new codes:
159 (O,R) MAF sensor is/was out of range – MAF
114 (O,R) IAT sensor out of range – IAT
327 (O,R,M) EGR feedback signal is/was low – EVR or PFE
341 (O) Octane jumper installed (information only code to notify you if it is installed)
226 (O) Ignition Diagnostic Monitor (IDM) signal fault – Ignition Systems
565 (O) Canister Purge 1 solenoid/circuit failure – Solenoids
566 (O) transmission 3/4 shift solenoid/circuit – Transmissions
558 (O) EGR vacuum regulator solenoid/circuit failure – EVR or PFE or Solenoids
At this point I'm not sure what I should look into or replace. I'm thinking there might be a ground short or something similar but I'm not sure. Any help or guidance would be greatly appreciated.
The new codes:
