austinrick
- Feb 19, 2009
- 0
- Ford
- Engine Size
- 3.0L
Edit: The problem with the right turn signal indicator appears to be resolved, at least for now.
After considering what else controls those two green arrows, I fiddled with the hazard lights switch some-- on/off, etc, etc --and even tried to squirt some quality contact cleaner down between the switch button and the little guide it rides in, hoping that it would dribble down onto the contacts, and both turn indicators are working reliably now, using turn signal switch or hazard lights.
Whether it's a semi-permanent fix is too early to tell. But it's working now.
So before you tear into the dash to fix a turn indicator, see if the problem isn't slightly dirty hazard lights contacts.
________________________
I will need to R&R this cluster in the coming weeks (or swap modules over to a replacement circuit board/housing assy.) and could use any tips or tactics, do's/don'ts to help with the process. I haven't found a YouTube vid that uses this particular instrument panel (that I get the impression is very common in the 93-94 models) and the Hayne's shop manual is only so helpful. Getting the dash trim pieces (bezel) away, disconnecting the two wiring harnesses, speedo cable, gear indicator, etc. are some of my concerns.
If you have any tips or advice, I'd appreciate your sharing it here. -thanks
