Acgallen
- Feb 20, 2020
- 8
- 19380
- Ford Ranger
- Engine Type
- 4.0 V6
- 2WD / 4WD
- 2WD
So I've finally reached the point where the long block is assembled (for the most part) and now I'm swapping the A9L mustang computer with the matching harness into the ranger. Ive dug around for a while trying to figure out what is necessary to splice. I've found (By Bob) that connector 39 (8 pin Green Connector) near the computer and connector 31 (Brown 8 Pin Connector) near the master cylinder needs to be adapted. I've had good luck with the 31, as I believe I've spliced it correctly, but I'm finding 39 to be difficult. The ranger corresponding connector is different as there is a 4 pin connector and another 2 pin. I believe the fuel pump inertia switch and the speed sensor +- are in these wires. Need help with the locations of the wires to splice.
After those 2 connectors, i have no idea what (if anything) needs to be moved over. I'm attaching all the pictures I've been using as a guide. The Edis module on the ranger is my biggest concern because the mustang harness doesn't have it. Not sure if alot of the connectors I pulled just wont be used again since im replacing the computer and harness. A lot of questions, any help would be greatly appreciated. I leave for FT Knox shortly and would like to have the engine at least in the car lol.
