1992 mazda b2600i lift/blinkers not working
#10 Racing
Elma WA
mazda
2.6
i would like to know more about the torsion lift for the front. And blocks in the rear also for some reason my left rear blinker stopped working and also my front right any help would be greatly appreciated
maskeet
Mazda
for the blinkers, did u check the fuse? and if it doesnt work after u change the fuse try putting in new bulbs.
TrucksGetDirty
4
Fort Collins, CO
4.0 v6
Check the fuse first, if it's not that... then you probably need a new bulb.
(basiclly what was said above me lol)
#10 Racing
Elma WA
mazda
2.6
i already changed the bulb ill check the fuse today
11
Check your harness ground wires also. When you turn the blinkers on, does the indicator blink really fast? Do you hear the flasher unit clicking really fast?
#10 Racing
Elma WA
mazda
2.6
when you turn the left blinker on the idicator light blinks slow and dim also the left rear doesent work but the left front does. When i turn on the right blinker the indicator light blinks very fast and bright and the right rear works and the front right doesent. it is not the fuses i checked them.
11
Check the ground and the bulb for the left rear. More specifically the ground. If it looks crappy, clean it off with some scotch brite, or a wire brush and reattach it and see if it helps. A corroded ground would be causing high resistance in the circuit. High resistance equates to low amperage passing through the bulb, it also could cause the bi-metallic strip in the flasher unit to not heat up as quickly as it should, thus the slow blinking. Try swapping the bulb on the right front with the left front bulb or a new bulb. The symptoms for that one directly resemble a burnt bulb. A broken bulb filament would cause less resistance in the circuit, less resistance equates to higher amperage. The higher amperage heats the flasher units bi-metallic strip quicker than normal, in turn causing your increased rate of flash on the right side.
Hope this helps, FWM.
#10 Racing
Elma WA
mazda
2.6
i replaced bulbs still the same problem i will check grounds win i get back from my vacation
11
Check for power coming to the front turn lamp with a test light while the blinker is turned on.
Boggin
48
I have the same truck with the clutch gone, Ill tell ya my torsion bars wouldnt budge, but my truck is very very rusty,
dont mean to jack the thread, but i would like to part out my truck and wonderin if you need anything? for example i have the 2 '4X4' emblems along with the 2 'B2600i' emblems right here next to me this very minute
#10 Racing
Elma WA
mazda
2.6
Do you have a good tailgate?
Boggin
48
its not mounted, its in my shed but i can take a look at it tomorrow and see what kind of shape its in,
its a great truck got alot of good parts just the clutch is the only problem and i really need to get some $$$,
If you need anything just let me know, Im on here everyday 3 or 4 times, you wont have trouble reaching me
anyways tomorrow i will have a look for you, Ill drop you a p.m.
treecuter08
va
mazda
2.6
i need parts to and hard to find around here
