For Sale 1992 4.0 V6
1BadRS
pinehurst, nc
I had picked up a 1992 Explorer to do the 4.0 swap into my 84 Bronco II, but decided to just stick with the 2.8 carb setup. The motor is pretty much as complete as you can get with radiator, hoses, fan. It has the front accessories with belt and exhaust manifolds all the way to the y pipe and converters.
Looking for a local pickup in Pinehurst, NC.
$500 or will trade
1BadRS
pinehurst, nc
I will part out the motor as well and can ship parts if need be.
thcscubajohn
31
Antarctica
FORD
247ci
4"
31x10.50r15
Smog is for pussies.
Is the harness for sale?
sumncguy
18
Hillsborough NC
at least 6"
32x11.5x15
Im in NC 27541 .. I have a 92 Ranger 4.0l 4x4 auto .. this is what I need ..
Need a power steering pump.
I need the two rubber gaskets from the hard black hose running from the throttle body to the Air cleaner if in good shape. Mines crumbling.
Need a gray drivers side door panel with a good arm rest and switches electric windows.
Need a black drivers side handle in and out if in good shape.
Need the two hoses off the evap canister if in good shape. Mine are crumbling.
Might need a tranny, a4ld 4x4 ... and I may eventually be looking for working 4x4 components.
Thanks
thcscubajohn
31
Antarctica
FORD
247ci
4"
31x10.50r15
I'm back again, can I buy the fuel line from the filter to the fuel rail?
dmperkins01
Mi
Ford ranger
driver side valve cover? mine is needing replaced
Shadowrider6661
D RANGED
ASE Certified Tech
127
Off grid Northern Arizona.
Stock
4"
N/A
33 x 12.50 x 15
Drive it, Break it, Fix it, REPEAT !
Do you still have the heads, rocker arms, and pushrods for it ? If so, how much ? I have no problem paying for shipping if you're willing to ship.
cee21
Clinton, TN
What gears are in the axles? Is it 4x4?
stamina
32
Wilmington, NC
3” suspension
265/75/r16
built her in a storage unit
$500 or will trade
i’m in wilmington nc, do you have the dash harness and a cylinder head? very much needed.
stamina
32
Wilmington, NC
3” suspension
265/75/r16
$500 or will trade
you still got that thing dude ? i live in wilmington
1BadRS
pinehurst, nc
I have some parts from the motor left, but not the complete assembly. What are you looking for?
stamina
32
Wilmington, NC
3” suspension
265/75/r16
do you have the short block and is the short block good?
Carlisle Truck Nationals
Join us at the Carlisle Truck Nationals for the 40th Anniversary of the Ford Ranger.
